Using a Wavlink AP
Bogart
Bogart Posts: 22  Freshman Member
Have a LTE7490-M904 which works fine. I am now wanting to add a Wavlink AC600 wifi extender configured as an AP. I use an unmanaged switch which seems to work fine. Problem I cannot get the AC600 to access the interent. Have spoken to Wavlink who are useless. The AC600 works fine when connected to another network I have but not the Zyxel mobile phone one. Am I missing something obvious?
  • SELBERG
    SELBERG Posts: 354  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    edited December 11
    You have latest firmware V1.00(ABQY.9)C0 ?
    https://download.zyxel.com/LTE7490-M904/firmware/LTE7490-M904_V1.00(ABQY.9)C0.zip
  • Bogart
    Have now loaded latest firmware but problem still present.
  • SELBERG
    You have a POE injector between your switch and AC600?
  • Bogart
    I have attached a drawing of how I have it wired up.
  • SELBERG
  • Bogart
    Hi
    Yes my mistake obviously the LTE uses its 48v psu not 24v as I showed. It does work if I connect a signal from a different router into the switch. That is why I am thinking the LTE is the problem.
  • Bogart
    Have tried various combinations. Different switch, a managed one, no difference. The Wavlink works fine connected into a different router so again finger of blame points to the LTE. Not so much as in its suitability more in as I think a setting is incorrect.
  • SELBERG
    Do you use router mode or IP Passthrough?
    If IP Passthrough try router mode, i think that could be your problem.....
  • Bogart
    Set passthrough to off and can now access internet. Strangely I set passthrough to on as with it off originally I could only connect one computer to it any more than one and it threw a wobbly. Will see how it goes.
    Thanks and have a good Christmas and New Year
