NR5101 randomly loses network connection (log says: QMI error)
After having worked well for about a year, my NR5101 stopped working correctly.
It disconnects to the network and stays disconnected. It also doesn't try to reconnect anymore. This happens about 6-9 times per week. The log file gives out QMI errors and the system freezes. Only a full reboot does help.
Below is the log file right before it happens. You can see:
- 06:56:40 - Connection is still up
- 06.56:49 - LTE connection is lost
- 06:56:51 - Tries to search
- 06:56:54 - modem is ready to re-connect
- 06:56:57 - This is when the Qualcomm MSM interface error happens and the whole system effectively freezes.
Nov 22 06:56:40 user.notice RILCMD: Current Tech = NR-NSA EN-DC, PCID:483, RFCN:100, DL_BandWidth:20MHz, UL_BandWidth:20MHz, RSSI:-60dBm, RSRQ:-8dB, RSRP:-88dBm
Nov 22 06:56:49 user.notice RILCMD: set_LTE_connection_status: Down
Nov 22 06:56:51 user.notice RILCMD: CREG_INTERNAL_NOT_REG_DO_SEARCH detected
Nov 22 06:56:52 user.notice zcmdModuleCfg: System: Wan interface Cellular WAN 1 connection lost
Nov 22 06:56:54 user.notice RILCMD: quectel_rg500q_ready() Next to RS_ATTACH state
Nov 22 06:56:57 user.notice RILCMD: Reset LTE module because of QMI error.
What I tried: I used the same SIM card in another device without any problems for many days, so I don't believe it's the SIM card. I also tried turning of auto band selection and stayed on particular bands to avoid switching - without any difference to the behaviour.
What can I do? I starts to get worse, too. It happened about 4 times a day recently and during things like video conferences, which is bad. Some research told me, that this might even be a hardware fault.
Just wanted to came to say that I NR7102 and I am having same issues. Started about a month ago and modem WAN connection keeps resetting couple of times / day. All I have in log files is this same haunting message:
Seems like a bug?0 -
Updated to latest firmware from 13/12-24?
Hi again!
I also installed the newest firmware when the issues started about a month ago. I have a very good 5G connection, and this area isn't very densely populated, so the connection (when it works) reaches almost 600 Mbit/s, which is the limit of my contract. The modem has been in place for about a year now without any changes to our setup.
I also use the same provider on my cell phone, and I don't notice any issues with it when the modem's connection drops. That "QMI module error" seems suspicious, and to me, it sounds like an issue with the modem itself rather than the signal.
The connection provider claims there are no current issues or events reported at the local towers. While it's possible they could be mistaken, I have a strong feeling the problem lies within the modem.
The error in the log file is:
RILCMD: Reset LTE module because of QMI error.Here are the log events leading up to the error:
182
Dec 30 14:14:01
user
notice
cellwan
183
Dec 30 14:14:00
user
notice
cellwan
RILCMD: RILCMD STATE: RS_UPDATE ============> RS_READY
184
Dec 30 14:13:59
user
notice
cellwan
RILCMD: RILCMD STATE: RS_INIT ============> RS_UPDATE
185
Dec 30 14:13:59
user
notice
cellwan
RILCMD: Change state from RS_INIT to RS_UPDATE.
186
Dec 30 14:13:59
user
notice
cellwan
RILCMD: Preffered Access Technology: Auto
187
Dec 30 14:13:58
user
notice
cellwan
RILCMD: PrevSetAccessTechnology: Auto
188
Dec 30 14:13:58
user
notice
cellwan
RILCMD: RILCMD_AUTO_APN flag enable.
189
Dec 30 14:13:52
user
notice
cellwan
RILCMD: Current activate MBN: ROW_Commercial
190
Dec 30 14:13:52
user
notice
cellwan
RILCMD: zcfg_get_CellWanConfig() doModuleReset = 1
191
Dec 30 14:13:52
user
notice
cellwan
RILCMD: zcfg_get_CellWanConfig ()item_ptr->refreshInterval = 10
192
Dec 30 14:13:47
user
notice
cellwan
RILCMD: GNSS function enable
193
Dec 30 14:13:45
user
notice
cellwan
RILCMD: NR7101 with RG500Q/RG502Q module
194
Dec 30 14:13:45
user
notice
cellwan
RILCMD: SIM card ready after initialization
195
Dec 30 14:13:44
user
notice
cellwan
RILCMD: Profile Shift = 0
196
Dec 30 14:13:40
user
notice
cellwan
RILCMD: [317] DeviceFirmwareVersion: RG502QEUAAR12A03M4G
197
Dec 30 14:13:40
user
notice
cellwan
RILCMD: Support Auto Connection: 0
198
Dec 30 14:13:36
daemon
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1
199
Dec 30 14:13:36
daemon
debug
dhcpd
dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {\"ac\":\"add\",\"expire\":\"298613\",\"mac\":\"20:23:51:59:00:e8\",\"ip\":\"192.168.1.185\",\"host\":\"deco-M5\",\"vendor\":\"udhcp 1.22.1\",\"moui\":\"*\",\"serial\":\"*\",\"pclass\":\"*\",\"cid\":\"01:20:23:51:59:00:e8\",\"ifname\":\"br1\"}
200
Dec 30 14:13:36
daemon
info
dhcpd
201
Dec 30 14:13:35
user
notice
cellwan
202
Dec 30 14:13:34
user
alert
cellwan
RILCMD: [RESET] State back to RS_INIT
203
Dec 30 14:13:34
user
notice
cellwan
RILCMD: RILCMD STATE: RS_UPDATE ============> RS_INIT
204
Dec 30 14:13:34
user
alert
cellwan
RILCMD: [RESET] Module state unsync with CM
205
Dec 30 14:13:15
user
info
esmd
esmd: receving ZCFG_MSG_WAN_INTERNET_LED_UPDATE
206
Dec 30 14:13:15
user
info
esmd
esmd: check3GWanStatus: Enter
207
Dec 30 14:13:15
user
info
esmd
esmd: wanConnctionLostHandle: Enter
208
Dec 30 14:13:14
user
notice
system
209
Dec 30 14:13:14
user
info
esmd
210
Dec 30 14:13:13
user
notice
cellwan
RILCMD: RILCMD STATE: RS_READY ============> RS_UPDATE
211
Dec 30 14:13:13
kern
debug
tr69
ZTR69: [STATUS] cwmp_main_proc(): ***state change to 1***
212
Dec 30 14:13:13
kern
debug
tr69
ZTR69: [STATUS] cwmp_main_proc(): ***current state=1, cmd=1***
213
Dec 30 14:13:13
kern
debug
tr69
ZTR69: [DB ] cwmp_cmd_proc(): ipcCmd=1, data={ }
214
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Close all the qmiclientIds of idx=0.
215
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Close qmiclientId[0][11] 54
216
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Close qmiclientId[0][3] 53
217
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Close qmiclientId[0][2] 52
218
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Close qmiclientId[0][1] 51
219
Dec 30 14:13:08
user
notice
cellwan
220
Dec 30 14:13:08
user
notice
cellwan
RILCMD: Rilcmd: Status change to Down.
221
Dec 30 14:13:07
user
notice
cellwan
RILCMD: cid[1]: ip address change from 10.188.204.205 to 10.156.73.208.
222
Dec 30 14:13:07
user
notice
cellwan
RILCMD: isChange=1, old IP=[10.188.204.205], new IP=[10.156.73.208]
There’s that ominous IP address change, which might indicate a problem at the mobile cell level rather than the device itself. However, it seems that every WAN IP change is followed by the next events and eventually the connection dropping.
Here is some basic information:
- Mobile Band: Auto Select
- Cellular Lock: Disabled
- Device Model: NR7102 (Serial: S220Z03005524)
- Firmware Version: 1.00(ABYD.3)C0
- Qualcomm Module Firmware: RG502QEUAAR12A03M4G (no updates found)
This device is now two years old. I got it as a replacement for my previous modem, which suddenly died on November 25th, 2022. These modems aren't the cheapest, but unfortunately, they seem to fail at a similar age.
I'm the OP and I can confirm that I still have that issue as well. I'm on the up-to-date firmware, of course. I also updated the modem module firmware which seemed to help a little bit - it's not as often anymore, but it still happens.
I have pretty much the same setup like the posting before: I have a great 5G connection, living next to a powerful cell tower, everything works great until the router decides to freeze with the QMI error. Other devices continue to work just fine.
What gets on my nerve the most is that after the QMI error, nothing works. I have to manually restart the router. That's especially nervewrecking when it happens when I'm in bed using my internet or watching Netflix and suddendly the connection is just gone. If it would at least reset automatically - but it won't! Even worse is the error when I'm not at home, but I need my WiFi up and running.
If at least the device would reboot on it's on when the error appears, then the problem wouldn't be as severe and I'm baffled that the firmware doesn't account for that. It does account for other connection loss cases, though - so it can't be that difficult.
My device is around one year old now. I still do have warranty, but it's hard to tell if sending it in will solve it, especially after the problem improved a little bit after the module update. On the other hand, it did work well for a year. So it still might be a degrading hardware issue.
I'm still in the process of collecting logs and doing some debugging here and there or trying out different settings to see if something improves. However, as it currently doesn't improve (and especially as others have the same issue), I guess I need to call up Zyxel (again) and see what the options are.
I agree that the devices aren't cheap and currently -after having been a satisfied Fritz-User for over a decade- I'm not convinced by their reliability, sadly. Probably we're lucky and someone from Zyxel is willing to take a closer look and do their on research.
I am also on a warranty, but as this is the second device malfunctioning and I need to make some arrangements to change the modem outside of the building, I am now looking for some other manufacturers as I have slight trust issues with Zyxel now (again). Funny thou, that I used to be against Zyxel because of their low quality of Pro devices when I was younger IT-guy 25 years ago and I decided to give them a try with these modems….
Sadly it seems that nothing is changed…0 -
Take off on an unforgettable journey with Run 3, the game that combines fast-paced action and gravity-defying stunts. As you zoom through enigmatic tracks, every move counts in this captivating universe of challenges!
-1 -
Prepare for a spectacular adventure in Run 3, where every jump and sprint takes you higher into the enchanting void of space. Join the race and conquer mind-boggling obstacles that will test your agility and reaction time!
-1 -
I dropped to LTE from 5G and at the moment it seems to be more stable. I know that it is not the solution, but give some ideas what is happening.
Hi @bastigrun,
What module fw are you using currently?
Mine is RG502QEAACR13A02M4G_ZYXEL.
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 484 News and Release
