Problem with Multy app
ALIASKA72
Hi. I have problems with my Multy X mesh system. On my iPhone multy app I can’t see my multy network. Tried to reset Multy X, but keep stuck on the adding second Multy or if I choose to finish with one, then on app showing that my primary multy is disconnected. On multy itself is solid white light and WiFi and lan is working. Apple app is latest.
Yes. I reinstalled app. App version is 2.6.1.231012. Phone is iPhone 15 plus
Hi @ALIASKA72,
Thanks for the update. Please help to send us the feedback on the Multy APP.
You can follow the below steps to send feedback on the Multy APPOur agent will check this issue after you send it.
Zyxel Melen0 -
@ALIASKA72 was the Support able to fix the problem? I have the same bug
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
