Problem initial setting Multy X
nikolaus11
nikolaus11 Posts: 3 image  Freshman Member
I have a problem with setting up the Multy X.
I use Samsung s22 Ultra with the Multy app version 2.6.3.240201.
The setup of the master only works until saving, node is set up and WLAN is created. In the screenshot you can see the last picture, it stays like this for about 2 minutes and then an error message appears. I have tried this several times.
My network at home is as follows:
DSL modem -> Pfsense (PPoE connection) -> Netgear 24 port switch
There is already a working WLAN with a different SID.
How do I get this set up?
