RAID1 degraded on NSA325 v2 after file deletion
Many thanks! I'll give a try as soon as I've completed a data backup.
So, here we are again :)
After completing a backup, first tried:
root@oniNas:/home/shares# /sbin/mdadm /dev/md0 --fail /dev/sdb2 --remove /dev/sdb2
mdadm: set device faulty failed for /dev/sdb2: No such device
So I checked:
root@oniNas:/home/shares# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1]
md0 : active raid1 sda2[0]
1952996792 blocks super 1.2 [2/1] [U_]
So I added sdb2 back:
root@oniNas:/home/shares# /sbin/mdadm /dev/md0 --add /dev/sdb2 mdadm: added /dev/sdb2
Checking md0:
md0 : active raid1 sdb2[2] sda2[0]
[>....................] recovery = 0.0% (1364352/1952996792) finish=214.5min speed=151594K/sec
But recovery, again, failed to go past 0.4%…
Now I have this:
md0 : active raid1 sdb2[2](F) sda2[0]
unused devices: <none>
Tried a couple of times, same result. Trying to do a repair/recovery from web interface, sdb2 is again removed from RAID.
Reading the post you linked, tried —query:
root@oniNas:/home/shares# mdadm --query --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Wed May 13 13:10:05 2015
Raid Level : raid1
Array Size : 1952996792 (1862.52 GiB 1999.87 GB)
Used Dev Size : 1952996792 (1862.52 GiB 1999.87 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Update Time : Fri Dec 27 11:14:30 2024
State : clean, degraded
Active Devices : 1
Working Devices : 1
Failed Devices : 1
Spare Devices : 0
Name : oniNas:0 (local to host oniNas)
UUID : adcf3210:50eaa529:cec15b96:3edc8d16
Events : 8258202
Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
1 0 0 1 removed
2 8 18 - faulty spare /dev/sdb2
What should I do now?
Read the kernel log after the syncing is aborted. I suppose some kind of I/O error occurs.
Tried:
su cp /proc/kmsg /tmp/kmsg2.txt
After a fresh reboot. I'm attaching the output to this message.
Seems the same as before..
Found this thread, can it be of some help?
Now, this happened:
root@oniNas:/home/shares# /sbin/mdadm /dev/md0 --add /dev/sdb2 mdadm: cannot find /dev/sdb2: No such device or address
I still have this:
root@oniNas:/home/shares# mdadm --query --detail /dev/md0 /dev/md0: Version : 1.2 Creation Time : Wed May 13 13:10:05 2015 Raid Level : raid1 Array Size : 1952996792 (1862.52 GiB 1999.87 GB) Used Dev Size : 1952996792 (1862.52 GiB 1999.87 GB) Raid Devices : 2 Total Devices : 1 Persistence : Superblock is persistent Update Time : Sat Dec 28 16:44:19 2024 State : clean, degraded Active Devices : 1 Working Devices : 1 Failed Devices : 0 Spare Devices : 0 Name : oniNas:0 (local to host oniNas) UUID : adcf3210:50eaa529:cec15b96:3edc8d16 Events : 8260622 Number Major Minor RaidDevice State 0 8 2 0 active sync /dev/sda2 1 0 0 1 removed
I'm curious why number 1 is "removed". Also, when I was able to add sdb2, it was added as number 2, and not as number 1.
Should I replace the sdb2 disk? Or re-initialize it in some way?
Many thanks
PS: some more details.
root@oniNas:/home/shares# fdisk -l Disk /dev/sda: 2000.4 GB, 2000398934016 bytes 255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x6178ba06 Device Boot Start End Blocks Id System /dev/sda1 63 1028159 514048+ 8 AIX /dev/sda2 1028160 3907024064 1952997952+ 20 Unknown Disk /dev/md0: 1999.9 GB, 1999868715008 bytes 2 heads, 4 sectors/track, 488249198 cylinders, total 3905993584 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000
Disk /dev/md0 doesn't contain a valid partition tableWeb interface is not responding anymore… Giving connection refused. But I'm still able to connect via ssh.
You misunderstood me. The idea was to initiate a sync, wait until it was aborted, and then read the kernel log, without rebooting. The kernel log is volatile. You can only read the last 16kB or something like that, and it doesn't survive a reboot.
But meanwhile there is another problem.
No matter if it's part of a raid array or not, mdadm should be able to find sdb2. And
# fdisk -l
should show sdb, and it's partitions. So it seems your 2nd disk is gone. It died, or maybe the SATA bus died. Again, the kernel log might tell, especially if you can still dump the moment the disk vanished.
You can check kernel logs with 'cp /proc/kmsg /tmp/kmsg2.txt'. That erases the log, but new lines can be added, and read with the same command. (Assuming you copied away /tmp/kmsg2.txt, or use another filename). dmesg should work, but for some strange reason it doesn't work for you.
I think I'll get another disk…
I recommend to wait until you know what the problem is. That NAS is at least 10 years old, I think. The SATA bus could be failing. Or the power supply. Have you the possibility to test the 'defective' disk in another system? Do you have another disk to put in that slot, just to see if it's recognized?
Ok, tried another cp /proc/kmsg /tmp/kmsg4.txt just after a power on, attaching output here.
And I can see an I/O error on sdb:
<6>sd 1:0:0:0: Device offlined - not ready after error recovery <6>sd 1:0:0:0: [sdb] Unhandled error code <6>sd 1:0:0:0: [sdb] Result: hostbyte=0x07 driverbyte=0x00 <3>end_request: I/O error, dev sdb, sector 3907029160 <3>Buffer I/O error on device sdb, logical block 488378645 <3>sd 1:0:0:0: rejecting I/O to offline device
Risking to go OT, as I just remembered/checked I have MetaRepository installed, I think from your repo, I'm sending a couple of screens, if you can suggest if I can / should upgrade something.
You are currently using firmware version : V4.81(AALS.1)
Many thanks :)
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 272 USG FLEX H Series
- 274 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 392 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 74 Security Highlight
