how to unregister device?
bkending
bkending Posts: 4  Freshman Member
How can i unregister device from portal.myzyxel.com?
on premise device flex 500
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 2,638  Zyxel Employee
    Hi @bkending,
    I would like to disable the security subscriptions that were included when I registered my device.
    Can I say you want to disable the security trial license from your device? If yes, please send me your device information, so we can help to disable it. Please correct me if I'm wrong.
    Zyxel Melen
  • bkending
    You are absolutely right.
    I have sent you info.
  • Zyxel_Melen
    Hi @bkending,
    Since portal.myzyxel.com doesn't support unregistering devices, could you share your purpose for the unregisteration?
    Zyxel Melen
  • bkending
    But I don't want to wait 30 days for the trial to end.
    So, my way of doing this is to unregister the device and register it again after 30 days.
  • Zyxel_Melen
    Hi @bkending,
    Zyxel Melen
  • bkending
