Zyxel Nebula FWA710: Online Gaming Problem
Cr4nk
Cr4nk Posts: 2 image  Freshman Member
Hi there,
I've got a FWA710 connected to a PoE-Switch XMG-108HP. Everything works fine, except Online Gaming Platforms (Steam, Epic, Battle.Net, …) - these applications do not connect. Any ideas?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,356 image  Zyxel Employee
    Hi @Cr4nk ,
    Based on our testing, we can successfully connect to all the gaming platforms you mentioned when using the FWA710 network. To help troubleshoot your connection issues, we suggest:
    1. Testing your SIM card in another mobile router to determine if your ISP has any gaming-related restrictions.
    2. Checking your FWA710's firewall settings by going to:GUI > Security > Firewall > Access ControlLook for any ACL rules that might be blocking access to gaming platforms.
    Zyxel_Judy
  • Cr4nk
    Thank you for your answer.
    1. The same SIM card works fine in another 5G Router of a different brand.
    2. No ACL rules were set, the router is basically in factory default settings.
  • Zyxel_Judy
    Hi @Cr4nk ,
    Since we are unable to reproduce the issue at our facility, we would like to schedule a remote troubleshooting session using TeamViewer or AnyDesk to better assist you. Our support hours are Monday to Friday, 01:00 - 09:00 UTC+0.
    Please let us know your preferred time within our support hours. For the session, please have the following items ready:
    • SIM card
    • FWA710
    • The alternative router that you use to connect to the gaming platform
    We will examine both routers during the session.
    You can securely share your TeamViewer or AnyDesk credentials by sending a private message through my account > Message.
    Zyxel_Judy
Nebula Tips & Tricks
