NR5101 randomly loses network connection (log says: QMI error)
bastigrun
bastigrun Posts: 9  Freshman Member
edited November 2024 in Mobile Broadband
After having worked well for about a year, my NR5101 stopped working correctly.
It disconnects to the network and stays disconnected. It also doesn't try to reconnect anymore. This happens about 6-9 times per week. The log file gives out QMI errors and the system freezes. Only a full reboot does help.
Below is the log file right before it happens. You can see:
  • 06:56:40 - Connection is still up
  • 06.56:49 - LTE connection is lost
  • 06:56:51 - Tries to search
  • 06:56:54 - modem is ready to re-connect
  • 06:56:57 - This is when the Qualcomm MSM interface error happens and the whole system effectively freezes.
Nov 22 06:56:40 user.notice RILCMD: Current Tech = NR-NSA EN-DC, PCID:483, RFCN:100, DL_BandWidth:20MHz, UL_BandWidth:20MHz, RSSI:-60dBm, RSRQ:-8dB, RSRP:-88dBm
Nov 22 06:56:49 user.notice RILCMD: set_LTE_connection_status: Down
Nov 22 06:56:51 user.notice RILCMD: CREG_INTERNAL_NOT_REG_DO_SEARCH detected
Nov 22 06:56:52 user.notice zcmdModuleCfg: System: Wan interface Cellular WAN 1 connection lost
Nov 22 06:56:54 user.notice RILCMD: quectel_rg500q_ready() Next to RS_ATTACH state
Nov 22 06:56:57 user.notice RILCMD: Reset LTE module because of QMI error.
What I tried: I used the same SIM card in another device without any problems for many days, so I don't believe it's the SIM card. I also tried turning of auto band selection and stayed on particular bands to avoid switching - without any difference to the behaviour.
What can I do? I starts to get worse, too. It happened about 4 times a day recently and during things like video conferences, which is bad. Some research told me, that this might even be a hardware fault.
  • Lanttu42
    Lanttu42 Posts: 4  Freshman Member
    Just wanted to came to say that I NR7102 and I am having same issues. Started about a month ago and modem WAN connection keeps resetting couple of times / day. All I have in log files is this same haunting message:
    Seems like a bug?
  • SELBERG
    SELBERG Posts: 360  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    edited December 2024
  • Lanttu42
    Hi again!
    I also installed the newest firmware when the issues started about a month ago. I have a very good 5G connection, and this area isn't very densely populated, so the connection (when it works) reaches almost 600 Mbit/s, which is the limit of my contract. The modem has been in place for about a year now without any changes to our setup.
    I also use the same provider on my cell phone, and I don't notice any issues with it when the modem's connection drops. That "QMI module error" seems suspicious, and to me, it sounds like an issue with the modem itself rather than the signal.
    The connection provider claims there are no current issues or events reported at the local towers. While it's possible they could be mistaken, I have a strong feeling the problem lies within the modem.
    The error in the log file is:
    Here are the log events leading up to the error:
    182
    Dec 30 14:14:01
    user
    notice
    cellwan
    183
    Dec 30 14:14:00
    user
    notice
    cellwan
    RILCMD: RILCMD STATE: RS_UPDATE ============> RS_READY
    184
    Dec 30 14:13:59
    user
    notice
    cellwan
    RILCMD: RILCMD STATE: RS_INIT ============> RS_UPDATE
    185
    Dec 30 14:13:59
    user
    notice
    cellwan
    RILCMD: Change state from RS_INIT to RS_UPDATE.
    186
    Dec 30 14:13:59
    user
    notice
    cellwan
    RILCMD: Preffered Access Technology: Auto
    187
    Dec 30 14:13:58
    user
    notice
    cellwan
    RILCMD: PrevSetAccessTechnology: Auto
    188
    Dec 30 14:13:58
    user
    notice
    cellwan
    RILCMD: RILCMD_AUTO_APN flag enable.
    189
    Dec 30 14:13:52
    user
    notice
    cellwan
    RILCMD: Current activate MBN: ROW_Commercial
    190
    Dec 30 14:13:52
    user
    notice
    cellwan
    RILCMD: zcfg_get_CellWanConfig() doModuleReset = 1
    191
    Dec 30 14:13:52
    user
    notice
    cellwan
    RILCMD: zcfg_get_CellWanConfig ()item_ptr->refreshInterval = 10
    192
    Dec 30 14:13:47
    user
    notice
    cellwan
    RILCMD: GNSS function enable
    193
    Dec 30 14:13:45
    user
    notice
    cellwan
    RILCMD: NR7101 with RG500Q/RG502Q module
    194
    Dec 30 14:13:45
    user
    notice
    cellwan
    RILCMD: SIM card ready after initialization
    195
    Dec 30 14:13:44
    user
    notice
    cellwan
    RILCMD: Profile Shift = 0
    196
    Dec 30 14:13:40
    user
    notice
    cellwan
    RILCMD: [317] DeviceFirmwareVersion: RG502QEUAAR12A03M4G
    197
    Dec 30 14:13:40
    user
    notice
    cellwan
    RILCMD: Support Auto Connection: 0
    198
    Dec 30 14:13:36
    daemon
    debug
    dhcpd
    dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1
    199
    Dec 30 14:13:36
    daemon
    debug
    dhcpd
    dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {\"ac\":\"add\",\"expire\":\"298613\",\"mac\":\"20:23:51:59:00:e8\",\"ip\":\"192.168.1.185\",\"host\":\"deco-M5\",\"vendor\":\"udhcp 1.22.1\",\"moui\":\"*\",\"serial\":\"*\",\"pclass\":\"*\",\"cid\":\"01:20:23:51:59:00:e8\",\"ifname\":\"br1\"}
    200
    Dec 30 14:13:36
    daemon
    info
    dhcpd
    201
    Dec 30 14:13:35
    user
    notice
    cellwan
    202
    Dec 30 14:13:34
    user
    alert
    cellwan
    RILCMD: [RESET] State back to RS_INIT
    203
    Dec 30 14:13:34
    user
    notice
    cellwan
    RILCMD: RILCMD STATE: RS_UPDATE ============> RS_INIT
    204
    Dec 30 14:13:34
    user
    alert
    cellwan
    RILCMD: [RESET] Module state unsync with CM
    205
    Dec 30 14:13:15
    user
    info
    esmd
    esmd: receving ZCFG_MSG_WAN_INTERNET_LED_UPDATE
    206
    Dec 30 14:13:15
    user
    info
    esmd
    esmd: check3GWanStatus: Enter
    207
    Dec 30 14:13:15
    user
    info
    esmd
    esmd: wanConnctionLostHandle: Enter
    208
    Dec 30 14:13:14
    user
    notice
    system
    209
    Dec 30 14:13:14
    user
    info
    esmd
    210
    Dec 30 14:13:13
    user
    notice
    cellwan
    RILCMD: RILCMD STATE: RS_READY ============> RS_UPDATE
    211
    Dec 30 14:13:13
    kern
    debug
    tr69
    ZTR69: [STATUS] cwmp_main_proc(): ***state change to 1***
    212
    Dec 30 14:13:13
    kern
    debug
    tr69
    ZTR69: [STATUS] cwmp_main_proc(): ***current state=1, cmd=1***
    213
    Dec 30 14:13:13
    kern
    debug
    tr69
    ZTR69: [DB ] cwmp_cmd_proc(): ipcCmd=1, data={ }
    214
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Close all the qmiclientIds of idx=0.
    215
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Close qmiclientId[0][11] 54
    216
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Close qmiclientId[0][3] 53
    217
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Close qmiclientId[0][2] 52
    218
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Close qmiclientId[0][1] 51
    219
    Dec 30 14:13:08
    user
    notice
    cellwan
    220
    Dec 30 14:13:08
    user
    notice
    cellwan
    RILCMD: Rilcmd: Status change to Down.
    221
    Dec 30 14:13:07
    user
    notice
    cellwan
    RILCMD: cid[1]: ip address change from 10.188.204.205 to 10.156.73.208.
    222
    Dec 30 14:13:07
    user
    notice
    cellwan
    RILCMD: isChange=1, old IP=[10.188.204.205], new IP=[10.156.73.208]
    There’s that ominous IP address change, which might indicate a problem at the mobile cell level rather than the device itself. However, it seems that every WAN IP change is followed by the next events and eventually the connection dropping.
    Here is some basic information:
    • Mobile Band: Auto Select
    • Cellular Lock: Disabled
    • Device Model: NR7102 (Serial: S220Z03005524)
    • Firmware Version: 1.00(ABYD.3)C0
    • Qualcomm Module Firmware: RG502QEUAAR12A03M4G (no updates found)
    This device is now two years old. I got it as a replacement for my previous modem, which suddenly died on November 25th, 2022. These modems aren't the cheapest, but unfortunately, they seem to fail at a similar age.
  • bastigrun
    I'm the OP and I can confirm that I still have that issue as well. I'm on the up-to-date firmware, of course. I also updated the modem module firmware which seemed to help a little bit - it's not as often anymore, but it still happens.
    I have pretty much the same setup like the posting before: I have a great 5G connection, living next to a powerful cell tower, everything works great until the router decides to freeze with the QMI error. Other devices continue to work just fine.
    What gets on my nerve the most is that after the QMI error, nothing works. I have to manually restart the router. That's especially nervewrecking when it happens when I'm in bed using my internet or watching Netflix and suddendly the connection is just gone. If it would at least reset automatically - but it won't! Even worse is the error when I'm not at home, but I need my WiFi up and running.
    If at least the device would reboot on it's on when the error appears, then the problem wouldn't be as severe and I'm baffled that the firmware doesn't account for that. It does account for other connection loss cases, though - so it can't be that difficult.
    My device is around one year old now. I still do have warranty, but it's hard to tell if sending it in will solve it, especially after the problem improved a little bit after the module update. On the other hand, it did work well for a year. So it still might be a degrading hardware issue.
    I'm still in the process of collecting logs and doing some debugging here and there or trying out different settings to see if something improves. However, as it currently doesn't improve (and especially as others have the same issue), I guess I need to call up Zyxel (again) and see what the options are.
    I agree that the devices aren't cheap and currently -after having been a satisfied Fritz-User for over a decade- I'm not convinced by their reliability, sadly. Probably we're lucky and someone from Zyxel is willing to take a closer look and do their on research.
  • Lanttu42
    I am also on a warranty, but as this is the second device malfunctioning and I need to make some arrangements to change the modem outside of the building, I am now looking for some other manufacturers as I have slight trust issues with Zyxel now (again). Funny thou, that I used to be against Zyxel because of their low quality of Pro devices when I was younger IT-guy 25 years ago and I decided to give them a try with these modems….
    Sadly it seems that nothing is changed…
  • blackarrow
    blackarrow Posts: 6  Freshman Member
    Take off on an unforgettable journey with Run 3, the game that combines fast-paced action and gravity-defying stunts. As you zoom through enigmatic tracks, every move counts in this captivating universe of challenges!
  • blackarrow
    Prepare for a spectacular adventure in Run 3, where every jump and sprint takes you higher into the enchanting void of space. Join the race and conquer mind-boggling obstacles that will test your agility and reaction time!
  • Lanttu42
    I dropped to LTE from 5G and at the moment it seems to be more stable. I know that it is not the solution, but give some ideas what is happening.
  • Friday
    Friday Posts: 93  Ally Member
    Hi @bastigrun,
    What module fw are you using currently?
  • bastigrun
    Mine is RG502QEAACR13A02M4G_ZYXEL.
