LTE5398-M904 support CLI?
Hello. I have a Zyxel 4G LTE-A indoor Router LTE5398-M904 with firmware V1.00(ABQV.4)C0. Tell me, does it support a Command Line Interface (CLI)? If it does, where can I find a list of supported commands?
Connect your computer to the router using an Ethernet cable or Wi-Fi.
Open a web browser and enter the default IP address of the router, which is 192.168.1.1, in the address bar.
Enter the default username and password, which are admin and 1234, respectively, and click Login.
Go to Maintenance > System > CLI and check the box that says Enable CLI.
Click Apply to save the changes.
del
This router does not have such an item in the settings menu.
The Zyxel LTE5398-M904 router does not natively support a Command Line Interface (CLI) for user configuration. Most of its management and configuration features are accessible through the web-based GUI.
If you're looking for advanced management features, you might need to check if Zyxel provides any specific tools or firmware updates that enable such functionality.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
