Strange log message. Is this an error?
Hi @Zyxel_Judy
Now… I have two different PoE log errors logged in this thread.
First log error:
“Port Detection Status is Searching”
“Port Detection Status is Delivering Power”Result of first log error:
The two actual ports did not flap down and up again
Attached units did not reboot
Attached units did not drop trafficSecond log error 30 days later:
“PoE power usage exceeds 95% threshold, remaining power is 0.0W”
“PoE power usage is less than 95% threshold, remaining power is 324.6W”
(ONE second between these messages)Result of second log error:
No PoE powered devices got problems or was powered down
Attached unit did not reboot
Attached unit did not drop trafficThis second PoE error has been seen before in march by two other persons. You offered a RMA for that person at that time, but he rejected it with the argument “Given that you couldn't replicate the problem and therefore have no fix, a replacement may suffer from the same issue.” (I did chat with one of the two that have seen this log with high PoE usage in the forum chat). To note is that he has not seen this message again.
As it is simply impossible during these circumstances that the power draw would go from my std approx 49W to momentarily over 95% of the switch max 375W which would be an increase of more than 7 times normal power usage, it must be either a hardware issue or a software bug. But… As no problem at all was seen with power or actual traffic on the switch ports, well, that could lead to not suspect hardware, but software/firmware!As this switch model has been around for a while and this log message has be up in the forum before with at least two different persons except me, I do wonder why you do not go through the firmware code and look at what in the code that actually triggers this log message. Just to offer an RMA when you have no clue if the same log message will/can appear again in the new replaced hardware, well, that bothers me… Just a response with “we are unable to replicate that problem” and offer an RMA, that bothers me.
I do very much appreciate that you took the time to look into the switch, but I am not satisfied with that you take it so easily.
I will in this case not go on with an RMA as I have not had any real issues except the log messages that you cannot explain. But if I will see any more of this log messages I will probably try to move away from this switch and replace it with something else. I.e send it back to where I bought it. It is simply too much for me with two different PoE log errors directly after moving to this Zyxel switch that you cannot explain and take so easily.
B t w… My switch has Hardware Version: V1.19. Do you have any newer hardware revision?
Hi @peos42 ,
Thank you for sharing your concerns. We recommend initiating an RMA (Return Merchandise Authorization) process for the following reasons:
- Your case presents an unusual situation where the Port Detection Status shows "Searching" or "Delivering Power," yet there are no apparent service impacts or practical issues.
- Since we cannot replicate the problems on our end, the issues may be specific to your device. A detailed examination of the hardware would help us identify any underlying problems.
To move forward, could you implement the RMA process and please provide us with: Device MAC address, Serial number, RMA number (via private message). Once we receive your device, our team will conduct a thorough investigation of the reported issues.
Please note that V1.19 is currently the latest hardware revision version.
Would you like to proceed with the RMA process? We're here to assist you with initiating it if needed.
Zyxel_Judy
Do you have any on-site fix/replace if paying for it?
How long will the RMA take?
How will my existing CLI license be added to the new device?
Is it possible to have another switch in advance? I can pay for en extra switch and get a refund when you receive the RMA unit.PS
I asked above…." I do wonder why you do not go through the firmware code and look at what in the code that actually triggers this log message.". Again… what in the firmware code will cause these log messages? Line voltage fluctuation? Is it possible for you to reveal what and how the triggers in firmware causes these log messages?
* “Port Detection Status is Searching”
* “Port Detection Status is Delivering Power”
* “PoE power usage exceeds 95% threshold, remaining power is 0.0W”0 -
Hi @peos42 ,
No, there are no local repair process in EMEA.
The turnaround time in EMEA is 10 working days
Once you request RMA#, local support will help you to transfer the license.
EMEA could change this case to pre-swap type, and you don’t need to extra payment.
The following is an explanation of the log in general.
- “Port Detection Status is Searching”
This log is generated when a Powered Device (PD) is disconnected from the port.
- “Port Detection Status is Delivering Power”
This log is generated when a Powered Device (PD) is connected to the port and starts receiving power.
- “PoE power usage exceeds 95% threshold, remaining power is 0.0W”
This log is triggered when the total PoE power consumption exceeds the 95% threshold of the switch’s capacity. This is expected behavior to notify the user when available power becomes critically low.
For your case, we will need to receive your device for further investigation.
Zyxel_Judy
0 - “Port Detection Status is Searching”
Hi @Zyxel_Judy
I now have logged an RMA according to your recommendation. While waiting I have seen the
"Port Detection Status is Delivering Power"again on port 6 and 7. And as before, the ports did NOT loose power. Still worked as it should with power and data. So I am actually not in a real hurry with the RMA as "these are just log messages"…
On port 6 - Cisco SLM2008 switch
Supports the IEEE 802.3af Power-over-Ethernet (PoE) PDOn port 7 - Axis M3026-VE camera
Power Power over Ethernet IEEE 802.3af/802.3at Type 1 Class 2
max 4.5 W, typical 3.4 WNow… My devices on port 6-7 are older devices (An Axis camera and a PoE powered 8-port Cisco switch), but had no PoE problems whatsoever with the old switch. And I have actually not had any problems with this Zyxel switch either... Only the log messages mentioned above that *may* / *could* be false messages. The PoE powered port 1-4 have top notch Aruba 505 and 535 AP:s and have not had this log message.
This Zyxel has more advanced PoE settings than the old switch. Could it be the case that there is something triggered within PoE negotiation ( I do not know the PoE std though). The strange thing though is that it happens within the same second on both ports, which could probably tell it is not a PoE negotiation thing or end device issue. But even so, I have now set "force-802.1at" on port 7 but not on port 6. So I will see if it happens again on both ports or just one of them as they now have different PoE config settings. But I doubt… as the ports log this almost synchronously.
Regarding the logs:
“PoE power usage is less than 95% threshold, remaining power is 324.6W”that have happened ONCE within the switch 40 day uptime and restored within the same second… And as before with the other messages, the ports did NOT loose power. Still worked as it should with power and data.
It must be a hardware or firmware issue. It is simply not possible for the six connected devices to draw this amount of power. Even if a short circuit should occur on o port it still has a max power draw on that port… Max worst case power for all six devices according to its devices specs are 5+4.5+13.5+4x26.4=128.6W. But According to the switch it mostly draw 45-48W in total during std usage.
My background in the business tells me it is a rather high probability that a new switch eventually could suffer the same issues. But that we will see when the switch is replaced…. And whatever happens after the replacement, it will add extra pieces to this investigation.
Hi @Zyxel_Judy
Just got a new one on RMA. Well… not "new".. It was heavily used and full of scratches and will go directly back with the supplied packing slip without being tested. Very disappointed.
I of course understand the unit I got must be working. But how many would accept such a heavily used and abused device as a replacement ? See pictures…
According to the amount of scratches it must have be abused a lot and used a lot! As the models have been around for many years, the replacement unit I just got can have been used for years. To then replace my unit that has been running for a month with a unit that can have been running for year, probably in a lab according to the scratches, that is not ok.
Is this a misstake or standard procedure by Zyxel? Let us hope it is a mistake by a single person and not standard by Zyxel…
Absolutely shocking! How can they send a replacement out in such poor condition?
I've had RMA's from other manufacturers and they've always been new units.
Hi @peos42,
Thank you for your feedback.
If the unit is a recently purchased item, we kindly ask you to fill out a new RMA request. When submitting the form, please have them include the following information:- Proof of purchase.
- The original RMA number.
- Specify that the request is for a DOA (Dead on Arrival) unit.
Additionally, when the support representative contacts you, please ensure they explain that the replacement will be a new unit.
Zyxel_Judy
0 - Proof of purchase.
Hi
I think that would ve very clear already as I uploaded info about my purchase (with purchase date on from nov 2024 it) when I did the RMA. Despite that, this is what I got. So with this in mind, what do think I should do?
And.. Now I am sitting here with my old original unit from nov 2024 plus the heavily used one I got on the RMA. So whatever happens, I have to send the one I just got directly in return with the packaging slip I got with it. So starting a new RMA again when the first one haasn't got in return could be messy. So I would need someone at Zyxel to handle it all. Not different persons… To add to that is my CLI license that has been moved to the unit that just arrived that I will send in return. This will cause me a lot of head ace.
Hi @peos42 ,
Apologize for any inconvenience this may have caused.
Please proceed with the steps above and include the note as "The request is for a DOA (Dead on Arrival) unit".
Thank you!Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
