NR7302 firmware upgrade
More stable but now on ABUV11
Hi, checking the product's user guide it seems it has cell lock function, I guess for both 4G and 5G.
I leave you the link of the user guide:
https://spdl.zyxel.com/NR7302/user_guide/NR7302_NR%20Outdoor%20OPAL-Series_UG_V1.00_Ed5_2023-09-25.pdfI am also interested on this router, should I buy it for € 200?
I already am owner of a NR7101 and it satisfies me, will I have the same experience with NR7302?
They look pretty much the same…0 -
the nr7302 is more compact and has esim in some firmware.
it might have better or worse performance in some cases because of different antenna design.
it has a 2,5g ethernet port.0 -
does someone have the fota url / xml of the A1 , telenor , zyxel firmware
Hi, does anyone have the firmware for the NR7302 where esim is enabled? I have the version from Germany last update via OTA shows the option to set a profile for Deutsche Telekom. Is there any OEM version of the firmware where esim is enabled? Alternatively does anyone have a version from Deutsche Telekom or A1 where esim is enabled? I am using with CZ Vodafone and Onenumber. I have the main plastic sim in the modem, and esim from Onenumber in the phone. But when I call the number, it is busy.I think if the main sim was in the phone and the Onenumber esim in the modem, this would not happen and the number could be called and the internet via the modem would work. Thank you and have a nice day.
- 441 Beta Program
- 293 Service & License
- 461 News and Release
