Switch XGS1930-52HP Cloud view
2»
  • Zyxel_Kay
    Hi @kellyjjones1
    To further analyze your case, we’ll need your assistance with some actions. We’ve reached out to you via a private message—please check your Community inbox.
    Kay
  • Zyxel_Kay
    Hi @kellyjjones1
    As discussed in our private message, the issue was related to the MTU size. It appears that your uplink device, likely at the ISP's end, has an MTU size limitation, which was preventing the switch from successfully connecting to the Nebula Control Center (NCC).
    To address this, we plan to improve the connection process between the switch and NCC to accommodate various ISP settings and ensure seamless connectivity. This enhancement will be included in an upcoming firmware release.
    Please stay tuned to https://community.zyxel.com/en/categories/switch-news-and-release for updates.
    Kay
