Nebula widget NOT working with mobile router
GiuseppeR
GiuseppeR Posts: 661 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited January 2025 in Nebula
Hello everyone,
I have setup a site where there is only a mobile router:
I put on my dashboard a pair of widgets like:
to see who is connected and why, but also if I connected 3 devices to that mobile router via its internal WiFi I cannot see anything.
Neither in clients area:
Is it correct to see nothing?
Maybe the clients linked to mobile router are NOT listed nor recorded in widget views?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @GiuseppeR,
    Yes, this is correct behavior. Nebula currently displays access point/switch/firewall clients. The widget displays the client information based on the client page information, therefore, it won't display the Mobile router's clients.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    Zyxel Melen
Nebula Tips & Tricks
