Hello
Hi @oregmagus
Thank you for your inquiry!
The 💎VPN Orchestrator feature is exclusive to Nebula Pro-level organizations. To access this feature, you'll need to upgrade your Nebula organization to the Pro level. Based on the device license information you provided, it appears some of your devices are using the Plus Pack, some are using the Pro Pack, and some are using the Elite Pack (which includes Pro-level features). As a result, your Nebula organization is currently on the Plus level.
For more details on how Nebula licenses work, please refer to this article:
How Nebula License WorksTo use the 💎VPN Orchestrator, you'll need to upgrade the Plus Pack license on the following devices to the Pro Pack license:
- 2x NWA50AX (Plus Pack expires on 2025-04-26)
- 1x GS1920-8HP (Plus Pack expires on 2025-04-26)
Feel free to reach out if you need further assistance!
Kay
Hi @oregmagus
Kay
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
