5G Problem with Router FEA710
I have a Zyxel FWA710 router. I Unfortunately the 5G connection to my provider doesn't work (only 4G). I tested with my mobile device: 5G is available at my location. I also have an old router (NR7301) at the same location; 5G works with this router. So the problem is with the FWA710 router. Does anyone have an idea?
Remove the personal information by Zyxel_Melen.
I checked this with my iPhone
Hi @Aschi,
From your iphone information, your iphone is not using 5G but 4G since it displays LTE.
Therefore, could you help to provide the cellular status on NR7301 so we can ensure 5G signal is available in your place?
Zyxel Melen0
 - 439 Beta Program
 - 2.8K Nebula
 - 200 Nebula Ideas
 - 6.3K Security
 - 499 USG FLEX H Series
 - 323 Security Ideas
 - 49 Wireless Ideas
 - 287 Service & License
 - 457 News and Release
 - 89 Security Advisories
 - 4.3K FAQ
 - 96 Security Highlight
