NR7302 firmware upgrade
124»
  • SELBERG
    SELBERG Posts: 361  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    More stable but now on ABUV11
  • sorryiamlate
    sorryiamlate Posts: 2  Freshman Member
    Hi, checking the product's user guide it seems it has cell lock function, I guess for both 4G and 5G.
    I leave you the link of the user guide:
    https://spdl.zyxel.com/NR7302/user_guide/NR7302_NR%20Outdoor%20OPAL-Series_UG_V1.00_Ed5_2023-09-25.pdf
    I am also interested on this router, should I buy it for € 200?
    I already am owner of a NR7101 and it satisfies me, will I have the same experience with NR7302?
    They look pretty much the same…
  • n_o
    n_o Posts: 57  Ally Member
    edited January 13
    the nr7302 is more compact and has esim in some firmware.
    it might have better or worse performance in some cases because of different antenna design.
    it has a 2,5g ethernet port.
  • n_o
    does someone have the fota url / xml of the A1 , telenor , zyxel firmware
  • n_o
    edited January 13
    where did you get v11
    @SELBERG
