5G Problem with Router FEA710
Aschi
Aschi Posts: 3 image  Freshman Member
I have a Zyxel FWA710 router. I Unfortunately the 5G connection to my provider doesn't work (only 4G). I tested with my mobile device: 5G is available at my location. I also have an old router (NR7301) at the same location; 5G works with this router. So the problem is with the FWA710 router. Does anyone have an idea?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    edited January 2025
    Hi @Aschi,
    Could you share:
    1. Your ISP name.
    2. Which bands are your ISP providing 5G service?
    Zyxel Melen
  • Aschi
    edited January 2025
    Remove the personal information by Zyxel_Melen.
  • Aschi
    I checked this with my iPhone
  • Zyxel_Melen
    Hi @Aschi,
    From your iphone information, your iphone is not using 5G but 4G since it displays LTE.
    Therefore, could you help to provide the cellular status on NR7301 so we can ensure 5G signal is available in your place?
    Zyxel Melen
Nebula Tips & Tricks
