Usglite60ax Non-Nebula vpn not monitoring
Our customers who use usglite60ax to make a non nebula site to site vpn do not see the connection status information in the vpn monitor section. I checked in 1-2 more places to be sure. I can't see that it is neither connected nor disconnected. In the picture in the image, there is an atp100 running on the other side and although the vpn is active, I can't see the status of the vpn connection in nebula. I think this happened after the last nebula update.
Hi @bymusty,
Thanks for reporting. We are investigating this issue and will update you once we fix it.
Zyxel Melen1 -
Thanks. Yes it is fixed and working properly.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
