Nebula Cloud Service Incident 2025-01-17 19:37 ~ 2025-01-18 04:07 (UTC+0)
Zyxel_CSO
Zyxel_CSO Posts: 501 image  Zyxel Employee
5 Answers First Comment Friend Collector Ninth Anniversary
edited January 2025 in Nebula Status and Incidents
Dear Nebula Users,
The system had some issues due to an incident.
Issue Started from:
2025-01-17 19:37 (UTC+0)
Resolved:
Issue Symptom & Risk:
  • Partial monitor data in NCC may loss.
  • Update at 1/20: Partial monitor data in NCC might displayed incorrectly.
Note: This incident does not affect Nebula devices and their local network services if there is no any configuration change.
If you observe any issues that do not match the symptoms & risks mentioned above, please contact @Zyxel_Support
We apologize for any inconvenience this has caused.
Zyxel Nebula Support
  • Zyxel_CSO
    Update at 1/20:
    After investigation, no monitor data loss. Only partial monitor data in NCC might displayed incorrectly.
