NR5103E firmware again
I just bought a used NR5103E. Since updated firmware is generally a good practice the first thing I did was to update it, but I did not pay attention to the important "E" in the end. Loading the NR5103 firmware into the NR5103E hardware resulted in a malfunctioning unit. It's not bricked, I can still access the web-interface and I do have a working LTE/5G connection.
The problem should be easily solved if I could just get my hands on any of the NR5103E firmware binaries. But after an hour with Google I have not had any success. This firmware seems impossible to find. Anyone out there with a copy to share?
What is the original NR5103E firmware before upgrade?
Regards,
Bob
I believe it was V1.00(ACBJ.0)b15Thanks!
//Patrik
Checked with a friend who has the same NR5103E. His firmware version is V1.00(ACDJ.0)b8_D0. So that one should work as well.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
