NAS326 remote power off
I'm running Windows 11. Is there an option to shutdown/power down via CLI? I've tried "ssh root@192.168.27.13 poweroff" and it responds with "Connection refused".
Did you enable the ssh server on the NAS? If yes, can you login over ssh?
I've enabled SSH under network/terminal, however I now get the response: "Unable to negotiate with 192.168.27.13 port 22: no matching host key type found. Their offer: ssh-rsa,ssh-dss".
My goal is to create a single command (including appropriate authentication) to put in a batch file to execute a poweroff function from my laptop on the same LAN.
Note: I can telnet ok - I receive the expected username/password prompts when connecting.
The ssh server is outdated, and the client by default considers it's encryption is inaccurate. You can tell him to shut up.
ssh -oHostKeyAlgorithms=+ssh-rsa root@nas
- Thanks - that lets me in.
- 1. Is there some way to make it persistent? I have no need of that level of security. Just a name/password will do adequately.
- 2. How do I include the password in the command so I don't have to enter it at the prompt?
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 285 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 251 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
