NAS326 remote power off
Teligence
Teligence Posts: 16 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
I'm running Windows 11. Is there an option to shutdown/power down via CLI? I've tried "ssh root@192.168.27.13 poweroff" and it responds with "Connection refused".
  • Mijzelf
    Mijzelf Posts: 3,047 image  Guru Member
    Did you enable the ssh server on the NAS? If yes, can you login over ssh?
  • Teligence
    edited January 2025
    I've enabled SSH under network/terminal, however I now get the response: "Unable to negotiate with 192.168.27.13 port 22: no matching host key type found. Their offer: ssh-rsa,ssh-dss".
    My goal is to create a single command (including appropriate authentication) to put in a batch file to execute a poweroff function from my laptop on the same LAN.
    Note: I can telnet ok - I receive the expected username/password prompts when connecting.
  • Mijzelf
    The ssh server is outdated, and the client by default considers it's encryption is inaccurate. You can tell him to shut up.
    ssh -oHostKeyAlgorithms=+ssh-rsa root@nas
  • Teligence
    edited January 2025
    • Thanks - that lets me in.
    • 1. Is there some way to make it persistent? I have no need of that level of security. Just a name/password will do adequately.
    • 2. How do I include the password in the command so I don't have to enter it at the prompt?
  • Mijzelf
    1. On Linux you could add a config line in ~/.ssh/config. No idea where that file could be located on Windows. -if it exists at all.
    But if you write a batch file to shutdown the NAS, it doesn't matter that the command line is a bit longer, does it?
    2. The canonical way is to use a key pair. A public key on the NAS in /root/.ssh/, and a private locally. Unfortunately that won't work in your case, as /root is on a ramdrive, so your public key won't survive a reboot. For admin it might work, but unfortunately admin has no right to shutdown the box.
    sshpass might do the job.
