SCR50AXE - not working app management and filtering
GiuseppeR
GiuseppeR Posts: 574 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I saw NO apps in the dashboard area:
While I have selected everything:
and:
I'm sure that onsite the office is working, so I think that it is a bug:
Please let me know what to do, to give back filtering benefits to this site.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,349 image  Zyxel Employee
    Hi @GiuseppeR,
    Your configuration is correct. The reason you didn't see the hits count is because your client didn't access any threats website and etc.
    Below screenshot is from my lab.
    In addition, my SCR50AXE lan interface use itself as DNS server. If your configuration isn't same as my, please correct your configuration. Also, SCR50AXE doesn't support to block DNS over HTTPS traffics.
    For more details, please reference this FAQ:
    Why content filter fail to work on security router? — Zyxel Community
    Zyxel Melen
  • GiuseppeR
    edited January 2025
    Hello @Zyxel_Melen
    I feel that something is not working properly.
    Name this site, where I have no reports, SiteX.
    Site1:
    Site2:
    SiteX:
    As you can see in SiteX it seems that I have NO internet traffic.
    It is NOT possible considering that there I have a dozen of devices:
    Please let me know how to unlock that device or if it has a damage/bug inside.
    I'm at your disposal, best regards
    GiuseppeR
  • GiuseppeR
    Hello @Zyxel_Melen
    the SiteX came back working as expected as soon as I changed the SSID config from WPA2 to WPA3:
  • Zyxel_Melen
    Hi @GiuseppeR,
    I checked with our engineer, and the issue with site X shouldn't be related to the security option of the SSID. But thanks for your update. We will do some local lab work to clarify it.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    I know that it seems strange, but if you need to test it I can give you full access to that Organization.
Nebula Tips & Tricks
