Nebula “Clients” section malfunction-bug
TipoTimido
TipoTimido Posts: 32 image  Freshman Member
edited January 2025 in Nebula
Good morning,
Today I added two devices to my home network, I go into Nebula to change the name appropriately in the Menu -> Clients but when I click on them I am immediately bounced to the Dashboard. What is happening? Why if I click on any Client I am bounced to the Dashboard?
Any clients in the list i click, it send me to the dashboard instead of the Client edit page, where in the past i was able to edit friendly name etc…
  • TipoTimido
    is there a limitation (i have only 31 device in the lan)?
    This seams to me a site priviledge issue???
    i need to edit the name of new client in my house…
  • TipoTimido
    Update: From Nebula mobile APP i can edit the name…sems the malfunction is onlu site side. Can someone test this and report to support center?
  • matteosaitta
    matteosaitta Posts: 19 image  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    edited January 2025
    It's happening on my tenant too, any time I try to open the client detail it will crash and reload the site to the main dashboard view. Any other panel works fine.
    Tested on Safari and Edge, on current windows and macos.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi users,
    We have confirmed the reported issue and are actively working on a solution. We will notify you once the fix has been completed and implemented.
    Zyxel_Judy
    Untitled Image
  • TipoTimido
    super thanks.
  • Zyxel_Judy
    Hi users,
    The issue is fixed. Please verify that the issue has been resolved on your end.
    Zyxel_Judy
    Untitled Image
  • matteosaitta
    edited January 2025
    @Zyxel_Judy Client detail page no longer fails to load. Thanks!
  • TipoTimido
    great! I confirm too that all work as before. Thanks for fast response and support!
  • TipoTimido
    Hi judy, another bug here → https://community.zyxel.com/en/discussion/28881/nebula-bug-on-device-configuration/p1?new=1
  • Zyxel_Judy
    Hi @TipoTimido ,
    We noticed you've created a new post there, so please continue the discussion in that thread.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
