NR7101 modem problem
Dear Zyxel,
I was an happy owner of a NR7101 outdoor modem.
From yesterday after update i got an error that don't detect the modem.
Additionally to this, there's no possibility to have a working sim.
What can i do?
Do you use passthrough mode or Router mode?
If passthrough change to router mode and do a reboot.
no, didn't worked for me. Set as router mode → no ip passt.
and LTE module is not detected in any case.
I read years ago that someone mentioned that the card was corrupted during an update.
It is recommended to remove the card during the update.
Have you tried a factory reset?
Maintenance / Backup/Restore / Scroll down to the bottom and hit reset.
Have you tried a different sim card?
factory reset multiple time.
all test run with and without sim card, i'm still struggling with this cpe.
I think is damaged and there's no way to fix it.
Did you try with another sim?
Yes.. 3 different Sims of 2 different isp
Additionaly I think if the software doesn't detect the module is not fault of the SIM
What firmwares do you use?
i tried several.. i reverted back to 05. tried 09 and 10.
none of them detected the lte module.
What module firmware?
are you serious?
first picture of this thread. Current LTE module : blank.
So there's no possibility to update the module, or to check what's there.
If i tried install a new module firmware, it said image is illegal.
I don't have time to waste on this rubbish product anymore.
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 345 USG FLEX H Series
- 289 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
