NR7101 modem problem
Arona
Arona Posts: 26 image  Freshman Member
Dear Zyxel,
I was an happy owner of a NR7101 outdoor modem.
From yesterday after update i got an error that don't detect the modem.
Additionally to this, there's no possibility to have a working sim.
What can i do?
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Do you use passthrough mode or Router mode?
    If passthrough change to router mode and do a reboot.
  • Arona
    no, didn't worked for me. Set as router mode → no ip passt.
    and LTE module is not detected in any case.
  • SELBERG
    edited January 2025
    I read years ago that someone mentioned that the card was corrupted during an update.
    It is recommended to remove the card during the update.
    Have you tried a factory reset?
    Maintenance / Backup/Restore / Scroll down to the bottom and hit reset.
    Have you tried a different sim card?
  • Arona
    factory reset multiple time.
    all test run with and without sim card, i'm still struggling with this cpe.
    I think is damaged and there's no way to fix it.
  • SELBERG
    Did you try with another sim?
  • Arona
    Yes.. 3 different Sims of 2 different isp
    Additionaly I think if the software doesn't detect the module is not fault of the SIM
  • SELBERG
    What firmwares do you use?
  • Arona
    i tried several.. i reverted back to 05. tried 09 and 10.
    none of them detected the lte module.
  • Arona
    are you serious?
    first picture of this thread. Current LTE module : blank.
    So there's no possibility to update the module, or to check what's there.
    If i tried install a new module firmware, it said image is illegal.
    I don't have time to waste on this rubbish product anymore.
