SCR50AXE - not working app management and filtering
Hi @GiuseppeR,
Your configuration is correct. The reason you didn't see the hits count is because your client didn't access any threats website and etc.
Below screenshot is from my lab.
In addition, my SCR50AXE lan interface use itself as DNS server. If your configuration isn't same as my, please correct your configuration. Also, SCR50AXE doesn't support to block DNS over HTTPS traffics.
For more details, please reference this FAQ:
Why content filter fail to work on security router? — Zyxel Community
Zyxel Melen0 -
Hello @Zyxel_Melen
I feel that something is not working properly.
Name this site, where I have no reports, SiteX.
Site1:
Site2:
SiteX:
As you can see in SiteX it seems that I have NO internet traffic.
It is NOT possible considering that there I have a dozen of devices:
Please let me know how to unlock that device or if it has a damage/bug inside.
I'm at your disposal, best regards
GiuseppeR
Hello @Zyxel_Melen
the SiteX came back working as expected as soon as I changed the SSID config from WPA2 to WPA3:
Hi @GiuseppeR,
I checked with our engineer, and the issue with site X shouldn't be related to the security option of the SSID. But thanks for your update. We will do some local lab work to clarify it.
Zyxel Melen0 -
Hello @Zyxel_Melen
I know that it seems strange, but if you need to test it I can give you full access to that Organization.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
