Adding cloud-based cameras in Nebula.
Hello Friends out there. Greetings from Sweden.
I am a new private user of Nebula and impressed so far but I have a problem adding my D-link cloud based surveillance cameras into my network.
I cannot reach my SSID from within the D-link installation software. I.e once my iOS is connected to the camera's network it fails to connect to my Nebula SSID.
Since D-link is a major player; I think many in the community have faced similar problem and there might be some solutions..
I guess a firewall issue or similar.
Hope to receive som relies.
Thanks in advance.
Kind regarsds
Hi @Bootheflyer
What is your AP model and your camera model? Please also check the WiFi 5 generation your camera supports.
If it supports WiFi 5 but your AP is WiFi 7 AP and enables MLO, it will not connect since WiFi 5 devices don't support MLO.
Zyxel Melen0
Can you elaborate on problem. Are you getting an error when you try connecting them via wifi? What are you ssid settings? Are you using WPA2-Personal or something else? Guest Network? Vlan? What model AP's or Firewall with built in Wireless are you using.
Hi @Bootheflyer
Zyxel Melen0
- 602 USG FLEX H Series
- 480 News and Release
