Zyxel Multi APP - second location
ok2025
i try to add a second location to my Zxyel Multi App.
Finding and configuration of the new Multi X works fine, but after this there is always an error "Setuperror" and Multy can´t be activated.
The new WLAN is working after this, but i can´t see the new Router in the App and i can´t change the destinations ? Already tried a lot of resets and a second router. Still same Problem.
Any ideas ?
Oliver
Hi @ok2025,
It seems like the certificate issue. Please send us feedback and our agent will help you to fix it.
You can follow the below steps to send feedback on the Multy APP
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
