DX3301-T0 EasyMesh/MPro Additional AP SSID status not syncing
kevxl
in Home Router
I have a Zyxel DX3301-T0 paired with a TP-Link HX220 running as an EasyMesh/MPro agent.
The main wifi SSID and password get synchronized, but the additional (more AP) SSIDs are being enabled by the HX220 even though they are disabled on the DX3301.
I assume this is an issue with the DX3301 as in agent mode there are no settings to adjust for the HX220.
Is there a way I can remove these addition (more AP) SSIDs or at least make sure the enabled/disabled status is properly communicated across the EasyMesh network?
you can go to network setting and select on wireless. then, you will see Guest/More AP, which you can disable it.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
