NR7101 Dead
Sudden failure of NR7101. New POE or Ethernet cable do not fix the issue.
no light comes on. No LAN connectivity. Warranty seems to have only been 2 years (looking at support website).
therefore I’ve inspected device. Seems the heatsink medium has come away from aluminium blocks so I suspect a hardware failure due to overheating. Would like to attempt a repair if anyone can help (I’m an engineer).
do you have a TTL adapter ?
i would start there , see if it tries to boot1 -
I don’t. Something like this? https://thepihut.com/products/usb-to-ttl-serial-cable-debug-console-cable-for-raspberry-pi?
I would benefit from some guidance on how to correctly use the cable to check functionality. E.g. what software would I run?
Thank you
Found the open source info with help of chatGPT. Going to use that: https://openwrt.org/toh/zyxel/nr7101?utm_source=chatgpt.com
apparently there is a range of serials with faulty Poe circuitry… if you open the antenna there are 12v solder points (for a barrel connector) next to the Ethernet connector.
I’ve isolated the fault to one of these components shorting to ground
Need help on which component to try replacing (so small I don’t want to start desoldering to work out which is causing fault to ground).
here to see if you find a solution since i think i have similar problem on the nr7101 as well.
WINNER!!
I've replaced MOSFET Q1 with IRLML0060 N-Channel 60V 2.7A SOT-23. Bit of a guess as there was no part number on the one removed. However, I have an oscilloscope and measured the voltage at 50Vac input, and the router should use about 1A continuous max.
The root cause appears to be the heatsink material on the back of the are where the MOSFET is mounted. A bit too much clearance meant there wasn't a solid interface.
Fingers crossed for many more years' of use.0
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
