impossible to update the firmware module on my device.
Hi @Arona ,
To better support you, could you share the device name and firmware version?
device name Nr7101 and firmware version is the last available on your website.
Hi @Arona ,
Which version of NR7101 are you using - the NR7101 with firmware V1.00(ABUV.11)C0 or the Nebula NR7101 with firmware 1.16(ACCC.1)C0?
I tried both with no success.. what do you suggest ? Otherwise I will throw it into the garbage
Hi @Arona ,
All module firmware of NR7101 can be downloaded at this link:
The module firmware names indicate both the version to be installed and the one to which you can upgrade. All updates must be installed sequentially, following the correct order, one by one.
- G502QEAAAR01A04-R11A03 - R11A03 Firmware - (from R01 (A04) to R11 (A03))
- RG502QEAAAR11A03-R11A06 - R11A06 Firmware - (from A03 to A06)
- RG502QEAAAR11A06M4G - R11A07 Firmware - (from A06 to A07)
- RG502QEA_R11A07 - ZYXELR13A02 Firmware - (from R11A07 to ZYXELR13A02)
- ZYXELR13A02 - ZYXELR13A04 Firmware - (from ZYXELR13A02 to ZYXELR13A04)
Please contact if we can be of any help.
yes but.. since the firmware in the system is not present.. what can i choose to start from? and .. always i try to update the system reply to me the image is illegal
Hi @Arona ,
We would like to assist you by checking your device directly and upgrading the module firmware through a remote session.
Could you please share your availability between 01:00 - 09:00 (UTC+0), Monday to Friday? You can send your TeamViewer/AnyDesk ID and password via private message by clicking on my account > Message.
really appreciate this.. !!!
here's what happens.
Tried with LAN and wifi. Both.
Maybe with the log file you can have a better view of the situation.
doing an update of the module the message is ( whatever version i try to flash )
and checked the firmware version:
Hi @Arona ,
Thank you for providing detailed information.
We are analyzing the issue and will contact you during your available time if a remote session is necessary.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 318 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
