NSA325 Samba share not working anymore
See instructions here
do you have new repo link?
Wel… according to this..
Release Notes for Samba 3.6.25
February 23, 2015Is 10 years old, older than Windows 10. Time is elapsed, time for a newer device, which could save a bit of power.
i am not planning to use it as main nas, i already have OpenMediaVault server but i want to repurpose nsa310s as backup host offsite.
also i did find the new link. now is there a way to install wireguard on nsa310s/armv5 for point-to-point connection?
I can understand the goal for not throwing away any functional hardware. However, if it would be a Windows 7 computer (which have far more updated security patches) with low power consumption I doubt you would use it.
Anyway: if your connection between onsite and offsite allows to use FTP i'd strongly suggest you to consider it as alternative.
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
