Unable to get Remote VPN working
Hi all.
I have a USG Flex 100 and I'm trying to get Remote access VPN working but am unable to.
I've set it up as follows.
I've validated that the dynamic DNS looking URL there (that I've blocked out) resolves back to the IP address that I am on by looking up the a record DNS for it and doing a whats my IP. That IP is not a private IP like 192.168. or 10.0. or 172.16.
I've checked and double checked passwords, secret keys and cloud auth users several times.
I'm trying to connect from my Mac laptop where I installed the downloaded configuration file from the VPN setup page.
I just get an error saying it can't connect, but I can't see any logs that suggest an authentication attempt is even made at the Firewall.
My fibre provider is Giganet. I don't have a static IP. The USG is connected directly to the Giganet modem.
Does your provider deliver on WAN interface a public ora private IP address? IF the WAN address is among private address your ISP should forward several ports to your USG Flex 100.
The IP that I get from whatsmyIP does not look like a private one unless I am misunderstanding what to look for. I get an address thats 188.74.x.x
Hi @Radial,
May I know your MAC OS version and could you help to enable Zyxel support access so we can help to check?
Zyxel Melen0 -
Support granted.
Running Sonoma 14.7.1
VPN settings like this ..0 -
Hi @Radial,
After checking, I found your firewall uses PPPoE to get a WAN IP address. But seems like your ISP provided you with a carrier-grade NAT (CGNAT) IP address. Therefore, the public IP you see is not the same as your WAN interface and you cannot connect with the remote access VPN. You need to contact your ISP if they can provide you with a normal public IP.
Zyxel Melen0 -
Checking with them now.
For future people searching this thread, I am with Giganet in Dorset. My connection was installed in 2023 so it is not a VLAN tagged connection like some of their older ones. They confirmed they only block port 25 on CGNAT but everything else is open.
Update here. Giganet have stopped offering static IP's which is what I need to get around this (despite this page still being live at the time of writing
). Apparently its something to do with the merger with Cuckoo Fibre and they don't offer static IP's anymore so there is nothing I can do. This is currently the only way I can get FTTP in my area. :(Thanks for your help @Zyxel_Melen
I don't agree with
unless your ISP do not put on writing the statement "you can't have public IP", which is different from static IP.
Static IP should mean that your ISP will provide you for the whole duration of the contract the same public ip address for the network connection.
Public IP means that directly (on the CPE/provider box at your site) or indirectly (through a network configuration done from your ISP) your connection will have access for the full TCP/IP stack (outside port 25, all the TCP and UDP ports, with some more other IP protocols) and you need a port forwarding/nat rule (IDK if made on the CPE or by the ISP) to your current firewall.
Now.
Access to your firewall when you're at your site. Check on the Firewall the ip address that WAN interface have. Then compare it with the result of whatsmyIP. I bet they are different.
If it's so, your ISP or you should configure a proper L2TP/IKE compliant nat/port forwarding rule to have your traffic delivered from the ISP to your zyxel box.0
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 345 USG FLEX H Series
- 289 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
