Incident Nebula??
everything seems online
When i click test:
Internet check: Ping check success
Internet check: Nslookup check success
Server check: Config Proxy hostname check success
Server check: Monitor Proxy hostname check success
Server check: Config Proxy socket check success
Server check: Monitor Proxy socket check fail
CP Server Connection Test: Success
MP Server Connection Test: FailWhat i also see, there is no reboot option for the firewall in the GUI? Its only physical possibile to let the device reboot? Or do i miss something
Hi @Dpj,
We are already clarifying this issue.
May I know if your local network of these sites is working?
Zyxel Melen0 -
it seems everything works ok
also the vpn site to site connections are looking allright
Do you want to receive the diagnostics file?
Hi @Dpj,
No, the Nebula connection test result is enough for us. Our engineer has narrowed down this issue and is fixing it now.
Once it is fixed, we will update this post:
Zyxel Melen0 -
Hi @Dpj,
The outage had been solved yesterday. May I know if any of your devices is still offline?
Zyxel Melen0 -
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
