[NEBULA] GS1920-8HP connected to Nebula - Unable to access local login
Best Answers
It should work, does switch reply when ping to it?5
@Quality_Drive_Away
You should be able to connect to the IP interface of GS1920-8HP and the username/password will be the configuration from Nebula in the General Settings.
5
@Quality_Drive_Away
5 -
Found it! Thank You!2
I joined my NWA1123 wifi access point to nebula and now I can't log in locally. Tried with both my original username & password as well as the username & password I use on the nebula website.
I don't see General Settings in the Nebula Control Settings.
Hi @flaccidupsilon ,
Welcome Zyxel community!
If your AP is online on NCC, you should be able to find your username and password in General setting page, location is at SITE-WIDE>Configure>General setting, then you can find the setting like below.
Hope it helps.
Thanks, that does help. I'm in now.
Two points: I didn't realize that my local password would be changed by connecting to Nebula. Second, you're the first to mention "SITE-WIDE", which was the key to finding General Settings.
Thanks again Jason!
- 441 Beta Program
- 293 Service & License
