Captive portal logout-ip deprecated
I have an ATP500 on Nebula with a captive portal. I had configured a logout-IP, and it's no longer working.
I had saved this KB, and it's no longer available. Why? https://support.zyxel.eu/hc/it/requests/466594
I used the following commands:
configure terminal
web-auth web-portal
session-page activate
exit
web-auth login setting
logout-ip 1.2.3.4
exit
Hi @Dylan96,
Regarding your question, it seems like this configuration worked before on this Nebula mode ATP500. May I know when it failed to work?
Zyxel Melen0 -
I set it up at the end of October 2024. I couldn't tell you when it stopped working, I just happened to notice it yesterday.
After restoring the default theme (we had configured a customised page) the logout url works correctly. But how come that KB was deleted?
Hi @Dylan96,
Apologize for the delayed reply.
I think this is because that link is a request topic. Once the request has been closed, the users will not be able to see this request. Let me send you a PDF of that request so you can keep the configuration steps.
In addition, I think this issue might be because you made some changes on Nebula. This caused the CLI configuration to be overwritten. You need to use CLI to configure it again.
Zyxel Melen0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
