Sony
2»
  • iconboy
    iconboy Posts: 9  Freshman Member
    thanks for the response,
    We can focus on the tv with mac address AC:50:DE:95:59:FB which has the strongest signal
    1. the ip is valid and does not conflict with any other ip address within the LAN, it also a static ip address.
    2. this ip is unique within the LAN
    3. This tv has a good signal, and I still have the same issue, I have to toggle the wifi on and off on this device for this tv to pick up any intenet connectivity.
    Please note at no time does the WIFI disconnect from the tv, it seems the connectivity becomes stale.
  • iconboy
    @Zyxel_Judy can I have an update on this please?
    PeterUK Posts: 3,775  Guru Member
    edited February 25
    Set TV to use DHCP and see if you still have a problem
Nebula Tips & Tricks
