Missing Password Sticker on Zyxel NR7302 - Any Solutions?
Hi everyone,
I recently bought a Zyxel NR7302 5G NR router on eBay, but unfortunately, the sticker with the default password is missing. Without it, I’m unable to access the router’s interface.
Does anyone know if it’s possible to replace or recover the password in this situation? Maybe a way to reset the router or contact Zyxel for support? Any tips or ideas would be greatly appreciated!
Thanks in advance!
I would also like to know if there is a solution in such a case?
We have mulitple Zyxel at our industry sites and some times get decommissioned where the label which was removed from the router and placed on the POE-Adapter is missing or the whole POE-Adapter goes missing. How do we gain the router password after a factory reset if its not "1234"?0 -
I'm in the same situation. Anyone had success getting the password?
have a look at
https://community.zyxel.com/en/discussion/27568/supervisor-root-password-generator-from-serial-number/p1?new=1
Please, I need the password too. Can someone help ?
My serial # is
S240Z18002625
Please I need the password too.
My Serial# is S240Z19005585
S240Z180026250 -
S240Z180026250 -
So many missing the sticker but how do you know serial if you can`t log in?🤔
there are 2 stickers:
one with mac , serial , imei , dt-material nr (not removeable)
and another small with admin password ( easy to remove , intended to stick on the poe injector )
on the nr7302 there is no wifi key on the first one1 -
Please, I need the password too. Can someone help ? Because i am in the same situation
My serial # is
S240Z18002999
Thanks in Advance
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 362 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 84 Security Highlight
