Nsa325 v2 can't see external drives from any usb
cantona
cantona Posts: 6 image  Freshman Member
Third Anniversary
Hi, I had a couple of years to use my nas and I wanted to transfer some files.
I tried with 2 external drives at all 3 usb ports, but I can't see them.
At log I can see that connected but…
"An external USB hub device is plugged"
"You are currently using firmware version : V4.81(AALS.1)"
Any suggestion please?
  • Mijzelf
    Mijzelf Posts: 2,981 image  Guru Member
    My first guess is a wrong filesystem. On external disks often exFAT is used, but unfortunately the 325 doesn't support that.
    If it's not the filesystem, you'll need shell access for troubleshooting. Do you have the ssh server installed?
