LTE5398-M904 don't see band 1 of TIM (Italy)
Marco179
Marco179 Posts: 5 image  Freshman Member
Hello, as mentioned by other users, the current LTE Module Version: EG18EAPAR01A12M4G , does not see the band 1 used by TIM (one of the main Italian ISP). Can you provide the file to downgrade to the EG18EAPAR01A08M4G ? Multiple users confirmed that the previous revision is free from this defect. Thanks.
  • Marco179
    SOLUTION
    In case anyone has this great piece of hardware with the worst zyxel assitance, here the solution to get the band 1 aggregation:
    1 - get admin access through ssh (online you can find some guides);
    2 - follow these instructions https://forums.quectel.com/t/lte5398-m904-lte-module-eg18ea/44568
    3 - probably the terminal will not accept the command as described in the post, so you have to use this format
    command='AT+QMBNCFG="list"'
    4 - reset and reboot
    5 - enjoy
    In a nutshell, the rev 12 and 13 of the lte module have inside a profile of a telecom operator "Telenor_Norway_Commercial " that limit the aggregation, with these instruction that profile is removed.
    I already informed zyxel support, but a correct upgrade is not yet released….so this is how much they care for their cusotmers, perfect strategy on how to kill a good product.
  • Marco179
    Very nice to be fully ignored by ZYXEL customer serice / assistance. The product has a clear defect because of the latest firmware (the band 1 is fully ignored / not usable) and the company doesn0t provide any assistance.
  • Marco179
    SOLUTION
    5 - enjoy
