Client List > All - Only 24 hours
SkyGoat
SkyGoat Posts: 41 image  Freshman Member
First Answer First Comment Friend Collector Third Anniversary
When on the Site Wide > Client list, if you select "Access point clients" or "Switch clients" or "Security gateway clients" from the first menu, the second menu then gives you options for Last 2 hours, 24 hours, 7 days, 30 days or Custom.
But, when the "All" option is selected in the first menu, the second menu only lets you go back 24 hours. Why can we not also have the same options available in the second menu?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @SkyGoat
    We opted to offer only the "past two hours" and "past 24 hours" options on the all-client page to enhance user experience. This is because the number of clients across the entire site is quite large—sometimes reaching thousands in certain cases. Selecting a longer observation period could result in significantly longer loading times, affecting user satisfaction.
    However, we understand that users may still need to track or review past connected clients. We have made longer observation periods available on individual device-type client pages to accommodate this need. Since the data is filtered in these views, the loading time is much faster, allowing users to retrieve the necessary information efficiently.
    Please feel free to share your comment or input~
    Zyxel Melen
  • Zyxel_Melen
    Hi @SkyGoat
    Zyxel Melen
Nebula Tips & Tricks
