How do I delete my Nebula account. I nede to og back to the normal access to my router
![[Deleted User]](https://us.v-cdn.net/6029482/uploads/defaultavatar/nN4PAQRO7TCNP.jpg)
Hi @Palle ,
Could you share which Zyxel router you are using?
Also, please confirm if your requirement is to manage and configure the router using the local management GUI.
Zyxel_Judy
I am using a Zyxel Nebula FWA510 router.
I can confirm, that I wish to manage and configure the router using the local management GUI.
Thanks for helping - with kind regards
Palle
Hi @Palle ,
With the FWA510, even if you register the router to Nebula, you can still manage and configure it using the local management GUI.
To access the FWA510's local management GUI, check whether your device is in Router mode or IP Passthrough mode, and then refer to the related article.
Zyxel_Judy
I dont understand most of the text. I have deletet something in the app, so I cant g’et any information. I have forgotten
either user or password. Are you able to remove the Nebula app and all settings, so I can use the information on the back of the router
Dear Judy
I finally managed to access the router. It turned out that I had reset the router at some point. I just didn't wait long enough, the router worked, but I couldn't access it. After another reset, I was able to access it. Thank you very much for your help and patience. Yours Palle0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
