Channel change on their own in Nebula, regardless of DCS
Hi all,
i think my problem is related to this. I have an NWA90AX and NWA50AX connected via SmartMesh setup in Nebula.
With disabled DCS i set the channels manually for both devices in 2.4/5GHz, but Nebula is doing it's own.
Setup:
NWA90AX: 11 + 36
NWA50AX: 6 + 44
Result after reboot for both is 11 + 44. When i use DCS nebula also sets both devices to 11+44 which isn't optimal. Any chance to fix this?
Regards, Christian
Hi Melen,
NWA90AX is the root AP, NWA50AX the repeater.
Best regards
Christian
Hi @ChristianW,
Thanks for the information. The repeater AP will connect to the root AP with its channel. However, it is strange that the root AP also changed its 5GHz channel. Could you help enable Zyxel support access so we can check? Please also share the timestamp you rebooted.
Zyxel Melen0
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
