Channel change on their own in Nebula, regardless of DCS
ChristianW
ChristianW Posts: 5 image  Freshman Member
Hi all,
i think my problem is related to this. I have an NWA90AX and NWA50AX connected via SmartMesh setup in Nebula.
With disabled DCS i set the channels manually for both devices in 2.4/5GHz, but Nebula is doing it's own.
Setup:
NWA90AX: 11 + 36
NWA50AX: 6 + 44
Result after reboot for both is 11 + 44. When i use DCS nebula also sets both devices to 11+44 which isn't optimal. Any chance to fix this?
Regards, Christian
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,642 image  Zyxel Employee
    Hi @ChristianW,
    May I know which is the root AP and which is the repeater?
    Zyxel Melen
  • ChristianW
    Hi Melen,
    NWA90AX is the root AP, NWA50AX the repeater.
    Best regards
    Christian
  • Zyxel_Melen
    Hi @ChristianW,
    Thanks for the information. The repeater AP will connect to the root AP with its channel. However, it is strange that the root AP also changed its 5GHz channel. Could you help enable Zyxel support access so we can check? Please also share the timestamp you rebooted.
    Zyxel Melen
Nebula Tips & Tricks
