confused about access and trunk ports
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
edited March 2025 in Nebula
I'm missing some knowledge about access and trunk ports, at least i don't understand something.
to start, we only use nebula based devices, no on premise.
i was understanding that when i configure an port as access port with pvid20 for example, this port belongs to vlan20.
But it seems it does not work this way. When i configure my desktop lan adapter with vlanid 30, my network adapter receives an ip addres from this vlan30.
So how to prevent this?
I was thinking must i configure it as trunk pvid20, and allow only vlan20? but why using access ports then?
i'm a little confused.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    edited March 2025
    Hi @Dpj,
    Is the management VLAN of this access port enabled? And the management VLAN is also VLAN 30?
    If so, you need to disable it first.
    If not, could you help collect tech support when this issue happens? So we can check the VLAN table and MAC table to investigate this issue.
    Zyxel Melen
  • Dpj
    Ok, when i have some time, i will make an clean configuration (now we use an template with many settings). to see if i have the issues still. If so, i will send the complete configuration.
Nebula Tips & Tricks
