Wrong IP Address
i configured my main wifi with vlan id 100, Clients will connect to my aps (nwa50ax) and get the correct ip addresses. Clients that will connect to my router (scr-50axe) will be connected to the correct wifi ssid but will get ip addresses from my management net. I can't figure out why. DHCP Server is external, not the router itself.
Vlan will only be used on my wifi interfaces and some ethernet ports.
Greetings Holger
Hello @h_winkler
Maybe editing the DHCP Settings for VLAN100 will help.
Hi @h_winkler ,
Based on your description, it appears that wireless clients connecting to the SCR50AXE's "winkler-wlan" SSID (with VLAN ID 100) are receiving IP addresses in the 192.168.88.x range. We've noticed that DHCP for VLAN 100 is disabled on the SCR50AX.
We recommend checking whether your SCR50AXE status is up-to-date, and your external DHCP server configuration to verify the subnet is configured as expected.
If you require additional assistance, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
Zyxel_Judy
- 597 USG FLEX H Series
- 480 News and Release
