Zyxel8825-T50 extremely slow USB network
2»
  • Sydney
    Sydney Posts: 8 image  Freshman Member
    edited July 2020
    Thanx for all the support, Hummel!
  • Frafor
    Frafor Posts: 1 image  Freshman Member
    Sydney said:
    SOLVED it myself eventually. For some reason the WPS button on the back has to be activated by keeping it pressed for over a second.
    It didn't tell in the installation process.
    Now I can copy around 8Mb/s.
    Hi Sidney, sorry to bother you after 1 year almost, but I'm not quite sure how you did solve the issue.
    I have the same router and I'm struggling to share even small files because USB drive speed drops to 300KB/s.
    I didn't understand exactly what the WPS button have to do with the USB drive speed and how this can solve the issue (it didn't in my case).
  • Jayvdw
    Jayvdw Posts: 1 image  Freshman Member
    Same here. I'm also running into this issue. Did anyone get it fixed?
  • Toeter
    Toeter Posts: 1 image  Freshman Member
    Same problem here, no solution yet, WPS button doesn't seem to do anything. A solution would be most welcome.
  • capsndave
    capsndave Posts: 5 image  Freshman Member
    I'm curious as well. I've just found this 'discovery' as I've been unable to improve my VMG8825-T50 above 300kb/s. It's often lower and frequently zero. From the experiences above it seems that there is a common fault. How does pressing the WPS button improve the data rate to the USB drive? 8MB/s would be fantastic.
    Sadly, I've gone back to an older model VMG3925-B10B which is achieving around 4MB/s.
