Update files (Switch) ?
On my GS1900-8, there are three "files" in the latest version:
- runtime-GS1900-8v2-V2.90(AAHH.1).bix → which I used for the update from http
- rom-GS1900-8v2-V2.90(AAHH.1).bix
- loader-GS1900-8v2-V2.90(AAHH.1).bin
What is the difference/use of runtime, rom, and loader?
Thank you in advance for this clarification.
Hi @Bibi49,
The runtime file is the firmware file for the GS1900 series, the rest of the files are for internal usage. Thanks for pointing out. We will correct the download file.
Update: the firmware was corrected on 3/25/2025.
Zyxel Melen0
Hi @Bibi49,
Zyxel Melen0 -
Thank's Melen.
You can delete this topic if you want.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
