Update files (Switch) ?
Bibi49
Bibi49 Posts: 10 image  Freshman Member
edited March 2025 in Switch
On my GS1900-8, there are three "files" in the latest version:
  • runtime-GS1900-8v2-V2.90(AAHH.1).bix → which I used for the update from http
  • rom-GS1900-8v2-V2.90(AAHH.1).bix
  • loader-GS1900-8v2-V2.90(AAHH.1).bin
What is the difference/use of runtime, rom, and loader?
Thank you in advance for this clarification.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    edited March 2025 Answer ✓
    Hi @Bibi49,
    The runtime file is the firmware file for the GS1900 series, the rest of the files are for internal usage. Thanks for pointing out. We will correct the download file.
    Update: the firmware was corrected on 3/25/2025.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Bibi49,
    Zyxel Melen
  • Bibi49
    Thank's Melen.
    You can delete this topic if you want.
